Help Date a Craftsman Box and Rivet Replacement Help
demiandvm
wi.
I picked up a Craftsman Heritage 2 drawer box that needs some TLC. When were these produced? I would like to remove the hardware to remove the rust and then remount after painting. I would prefer not to use pop rivets. Does anyone know of a method to use regular rivets to remount the hardware so that it looks more original? I was considering using stainless steel machine screws possibly. Interestingly, the drawer locking mechanism is activated by 2 slides on each side of the box instead of in the back like the grey/red boxes of the 60/70's. Note picture. Thanks for any help.
bonneyman
Desert SW
I use SS machine screws for my Craftsman box restos. Only thing you have to watch out for is how far in the screw penetrates. Sometimes there's interference issues with other parts.
I'm not personally familiar with that style of box, but I'm sure one of the experts on the forum can date the name plate.
D
demiandvm
wi.
Thank you for the pictures of your box. I think I will use SS screws too.
LB-1911
Northwestern Il.
Based on logo 50's era
MShaw
York, Pa.
I have used stainless steel button head socket screws. Look very nice. This is on a MW Powr Kraft box I did recently.
D
demiandvm
wi.
Are these screws commonly carried by well supplied hardware stores? Should one ask for button head socket screws?
My local Ace carries them.
I saw a toolbox resto where they used something that looked like binding post (Chicago bolts, *** bolts in different vernaculars), with super wide shallow heads, and very fine threads. But they were really small, much smaller than any I had seen before. Maybe they were tiny screw rivets for leather. No exposed threads on the back side.
MShaw
York, Pa.
"Are these screws commonly carried by well supplied hardware stores? Should one ask for button head socket screws?"
I got mine at McMaster Carr. Yes they are called button head screws. 1692710507994.png
MShaw
York, Pa.
6-32 X 5/16 I seem to remember that on the narrow drawers where the hole was partially in the double thickness material at the corner the screw was barely long enough. If you don't mind the length inside the drawer 3/8 long would be a better choice. In my box one handle hole is elongated to allow for manufacturing errors. I used flat washers under the nuts.
D
demiandvm
wi.
I hope you don't mind me asking MShaw. I see where the button screws are sold in packs of 100. I only need 15 for my box. Would you have left extra screws that you would want to sell 15-20?
