I need some help deciding if I should call an electrician or the A/C guy first for this problem.
Yesterday my wife noticed the lights were flickering occasionally and immediately assumed the house was about to burn down. I don't enjoy seeing the Mrs fret like this so I went outside where she couldn't keep bothering me only to find that I noticed the light flickering too.
From what I can see flickering only happens when the AC compressor is running so I checked the voltage around the house, then at the mains where they join the fuse box. I found a difference in voltage between the mains and a bigger difference when the A/C is running so I called the power company today to check at the meter.
Listed below are my readings on each main when the A/C is off and running and the notes the POCO left for me when I got home.
I measured voltage on each leg where the mains connect to the panel
AC Off 121.4 - 119.3
AC On 119.5 - 115.6
Fantastic notes left by the POCO:
He changed out all connections from pole to weather head and tightened all lugs inside meter base and tightened the outside main breaker wires.
He measured:
No load and connected but AC not running 122 - 120 - 242
AC off Amps 2 - 1.5
AC on Amps 22.5 25.6
Any thoughts on this? The flickering lights is a new thing so I need to have it checked but I don't know if my first call should be the A/C guy to check the compressor since it's about 15+ years old or an electrician.
AC On 119.5 - 115.6
He measured:
AC off Amps 2 - 1.5
