pixelmonkey
i want to use all of my yard!
the first attached image is a birds eye view of easements. the section i'm going to build a bridge for is over the blue stripe. the stripe is a concrete storm drain *ditch* thats 15'3" across and the full width of the yard. the ditch is 3' deep which exceeds the flow of a 100 year flood plain.
the red stripe is natural gas pipeline. the blue is storm drainage. the yellow is power and cable under ground.
attached a couple of images to help.
i want sides that i can add vertical post or bolt chain link fence wire to so the pups are safe. the height of the fence is 4' for the section in red. 3' for the section in yellow.
The bridge must be moveable. it needs to be wide enough for a push mower to cross, stable enough a kid cant turn it onto it's side or drag it into the ditch. i cant build a drawbridge due to easements on both sides of the ditch.
lets see ya be creative!
chris<pixelmonkey>
chris<pixelmonkey>
or out of the area completely? And does the easement mean no permanent structure on either side of the Moat? (sounds better than ditch)
Doesn't look as pretty, though.
