Use 5/4 decking boards instead of 2x4s or some of that composite decking, dunno the weight on it but it's 'green' and will last longer.
That composite decking is nice, and also extremely expensive. not worth it imo.
more photos to come that show some of the final cuts...Looks good to me! Are you planning on putting any close spaced spindles on the railing? Doesn't really matter on private property, but it wouldn't pass code if it were on public property.
sealing with a 50/50 mix of boiled linseed oil and mineral spirits.Don't forget to seal the wood to prevent it from weathering/rotting in the future.
have plates coming. the current washers should get it by until next week when the plates are installed.Also watch those two bolts holding the railing to the stringers. I hope you have a steel plate backing to prevent the bolts from pulling out. Standard washers won't help due to the large moment (torque) at those bolts due to the tall railing.
the eye bolts on each side are present for using a cable or strap to connect to. the moveable part is the ability to hook to the front bucket on a large backhoe and slide it into the yard. doubt it ever happens, but the design has worked for the approval from the city. i'm thinking at most, in it's life time, it will need to me moved 2 or 3 times.How is this mobile or moveable? (that was the key requirement right?)
I can see the dogs love the extra space...but what about driving a lawnmower up onto it?
I have a question. It appears as if each side of the bridge (because I'm not sure what side the eye hooks are on) has the metal fence poles right at the end of the bridge. Wouldn't those impede the progress of sliding the bridge into the yard?
Very nice bridge though.
-Dan
