I have a detached heated garage built on a 4" concrete slab. The garage is mounted with a pressure treated bottom plate secured to the concrete with closed cell foam in between. The concrete slab is sitting well above the snow and doesn't have any standing water next to it yet the floor is soaking wet on the edges. Is this condensation from the hot moist air in the garage? How do I fix this moisture issue? Should I caulk the groove formed between the bottom plate, drywall and concrete?
