HELP - Gold bolt with an "8" on it?
SMJ0104
Milwaukee, WI
I found a bucket of these in my warehouse. They seem to be copper but I'm not sure. They are 5 1/2" long and have a "8" on the hex head. 1/2" threads. Any ideas what these are and/or what they are for? Value? Thanks!
EOC_Jason
Bentonville, AR
I've never seen a copper bolt before, I would think it would be too soft... They do make BRONZE screws / bolts...
It's probably a regular bolt with a zinc coating.
It's probably just a grade 2 bolt, if it were a real grade 8 it would have 6 radial lines on the top, that is the standard.
If it's metric, they will stamp 8.8 on top for its grade... But with just the single 8 I'm kind of at a loss.
jakemac
New England
My WAG is that they're grade 8 (hardness) bolts made before the current marking standard, or by a manufacturer that decided to use their own marking instead of the standard.
4xdog
Santa Fe, NM
There have been a lotta bits made in beryllium-copper (Be-Cu) alloys over the years for nonmagnetic and non-sparking properties.
These bolts could easily be Be-Cu. Are they mangnetic? That's a quick test for surface treatments on steel or monolithic construction using a nonferrous alloy.
1982fxr
Phoenix
been many other marking over the years other than the basic ones we always think of...
SASORacing
Utah
go to a home depot or lowes, there are dozens of "grade 8" hardened bolts!
the better ones are the 10+ with the better head that looks like it has a integrated washer.
gtermini
Amity, OR
Odds are they are bronze. They used to be common for marine use. They are a reasonably tough alloy. I'd use them exactly as you would in place of any grade 5 steel or stainless bolt.
As for value, probably about worthless for resale, but you'd have to take out a 2nd mortgage to buy new replacements.
Greyson
PBCampbell
WV
Turn that bolt 90 degrees in that second picture and you'll see it's an "infinite" grade.
:lol:
kd3pc
Northern Neck
In the 1970's I used similar ones to bolt high voltage switch gear and buss bar together...they may be copper?
I would use them, but not count on them being grade 8
shanny19
PNW
If I had a bucket of those, I'd get them to the recycle yard and get them converted to tool-buying cash.
monomach
Illinois
Copper bolts just tossed in a bucket for who knows how long would have at least a little verdigris on them, probably.
In any case, a lot of old grade 8 bolts did have an 8 on the head. I've never sen an 8 on the head for anything else. Those are just zinc-plated grade 8 bolts. Not going to be worth the crazy money copper would have gotten you from the scrapper, but at least they're good for using.
