56nash
I am not a machinist or mechanical engineer. I am an Electrical Engineer in need of some help identifying some mechanical parts so I can go source raw materials to repair a piece of equipment in our shop. The manufacturer tells us the machine is now a legacy product, in other words we will custom make you the part and poke out your eye as well as empty your wallet. I have a drive shaft that is .375" (3/8) 16 splines that slips into a tube that is .875" (7/8) that is the same spline and at one end there is a .75" (3/4) u-joint welded to the female splined tube and the shaft has a .75" u-joint also. I can get the machine work and have the joint tig welded to the shaft if I can just find a source for the pieces. My manufacturing operation is line down until I find a solution. This is a part to a wave solder machine manufactured some 20 years ago. I would give my left one for a new machine, but that is not in the cards for a little while. Any sources for the raw materials would be appreciated.
