Help ID old MF brace
Half-fast eddie
Virginia
I have 2 Millers Falls corner braces. I acquired one in good condition, and the model number is clearly visible, its a 502. The second one was in filthy condition, looks like it has led a hard life. Got it cleaned up, found the trademark: also MF. It’s hard to read, looks like it might be a 502 as well.
The chuck is similar but different, the Y-casting is different, and the vertical arm has an offset.
Here are closeups of the trademark, it’s faint. I had read that the 502 became a cheaper 502A, and then they dropped the A. Is this the economy version?
From flipping through oldtoolheaven, which you’ve obviously already done,I’d guess the difference might only be in the wood. It’s obviously not a 512.
I would guess 1917 -22 for your nice one, cuz that doesn’t look like tropical hardwood or cocobolo. Need to clean the wood up a bit on the other to decide.
Or it might be really late, as the 1974 catalog does not show the inserted wrist handle rings
good to hear, I was looking on my phone, and couldn't see the differences in the Y connector that shows up clear as day on the big screen.
H
Half-fast eddie
Virginia
Can you help interpret the finish please.
Frame black enameled … that’s the round rod frame, right? So other than the chuck, what does thatvleave for nickle plate?
