Help ID plastic gear set?? Maybe lathe?
WisJim
Menomonie, WI
These plastic gears came with a bunch of machinist related items at a local auction, and I think that they might be change gears for a cheap imported lathe. Any ideas? Center hole is about 7/16". I don't want to throw them out if they might be of use to someone.
RoninB4
Under My House
If there are different numbers molded onto the surface of the gears, indicating the number of teeth per gear, then they are likely a set of change gears for threading on a cheap imported lathe.
W
WisJim
Menomonie, WI
That's what I thought, hoping someone can identify the lathe. They are numbered but hard to read some of them.
vwtrey
Pahrump, NV
I had a Harbor Freight style mill/lathe/drill combo that used those style gears.
HQ400 by Chizhou.
