Help id this compressor pump.
The Tool Tyrant
Bonita, Ca. (San Diego)
I concur..SB 707. SB pump sheaves are beefy cast units and don't break without 'help', which more often than not happens when a compressor hits the ground. If you're thinking of purchasing it, be sure to run a dial indicator on the end of the crankshaft to check run-out.
Jswain
Calgary, AB
And if it is indeed a clone then it will likely be a different size you will have to measure the od of the shaft.
Looks like the top of the motor pulley is broke as well so that tells the story of what happened im sure lol
