Help ID vintage Clausing lathe
slowtwitch73
Hellgate
i see a lot of other things on the floor. Just getting to it could be daunting, me thinks
Uh huh.. looks like parts for other lathes... that faceplate on the floor looks to be a thread on but the lathe has some size of 'L' nose.
I really like the L style of spindles and chucks.
i4ni
I know of another old lathe (19" leblond Regal) for sale that would be a challenge to move (it's in an enclosed porch) and it must be removed in 4 hrs on a specific day. I dont think theres much in the way of tooling. Maybe a smaller chuck and a steady rest. What's something like that worth? Hassle not included
paulsomlo
Northern Colorado
@930dreamer Are you looking at buying? That's one hell of lathe - looks like about a 2" spindle bore. If it's in any kind of decent shape and it's going cheap, and you have the means to move it, go for it.
930dreamer
Amarillo,TX and Stinnett,TX
Trying to get detailed information from the seller. Doesn't look ready to load. Looks like a Clausing Clochester Mascot 17". Seller didn't know the model, asking $2500.
dutchgray
Dorset. England.
Yes a Mascot, in the 2 to 2.5 ton range, 3 1/8" spindle bore, 17" swing, that one is a straight bed, various RPM ranges the best topping out at 900 rpm, so if you want to make a lot of smaller parts it won't be as good.
At least 50 something years old and it looks pretty crusty and unused for a long time.
In reality if its a good lathe or not will come down to condition but you won't know until its been cleaned and you can properly test it.
Best you can do in that state is have covers off and inspect everything for obvious wear and damage
PowerWagonBuilder
NW of Richmond, Va
^ This is correct! That one is the "Dominion" model, ie short bed, without the removable Gap, and the carriage and tailstock are lighter built. The large bore on the machine and the low RPM (26) is a very nice machine for some heavier work. That one looks to have the 2 speed motor control so hopefully it still has the original motor too.
I have the Mascot "Mammoth" in my shop, and it has the removable gap bed, 80" centers, and the carriage is setup for T nuts etc for using it as hz boring / milling setup. Mine scaled in at 5200 lbs with the chuck and tailstock on it. I have a Youtube video of moving it when I bought it a few years ago.
I have used mine for all kinds of work so far and it was / is pretty much my Home shop dream lathe. I started out with a 15" Triumph gap bed model, and then picked up a 6" student (12" swing) and then sold the Triumph to purchase my Mascot Mammoth.
Turning a set of Ford SD 8 on 170 to 8 on 200 dually hubs into 8 on 170 to 8 on 6.5" dually adapters.
However, the removable Gap bed is very nice for the few times you need it. I have a 26" diameter faceplate for mine that gets used occasionally. I needed to turn a different taper in this compressor wheel than what it had originally in order to run it on a different pump.
If the bed isn't damaged or horribly worn, that lathe is worth the current asking price.
