Help Identifying Craftsman ratchet
Good day everyone,
I am not tool expert but I think I have a nice ratchet here and I can tell it was us made by the stamp so I don't want to go swap it out for a Chinese version. I want to identify it so I can get a proper rebuild kit for it and get years of use out of it. I appreciate any assistance.
Shiftless
East Bay SFO
Welcome to GJ
I don’t have a lead on a rebuild kit but let me congratulate you on your find. That ratchet is certainly worth rebuilding and is way better than the new ones. It’s a RHFT in case you aren’t familiar with the lingo. That stands for round head fine tooth. I have several in my toolbox.
Lets stand by for an expert to chime in, but in the meantime, I’m gonna guess that it dates from the 70’s or 80’s.
Pinemarten
Washington
I bought 3/8" and 1/4" new at Sears in the late 70's. I recently dug out my 1/4" and removed the snap ring and cleaned and greased it. Works almost as good as new! You may not even need a rebuild kit.
D
My best guess based on research is that is is a Long lever available from roughly 57-60 individually and about as late as 63 in some kits. I would love for someone to be able to tell me I am right or even wrong lol
dchawk81
You are right or even wrong.
You're welcome. 😃
WWheeler
Middleofnowhere USA
Yep. Sears never assigned those a proper name nor a part number for that ratchet, but they are known colloquially as a long lever (as was the quick release version that came after, which makes it all the more confusing).
This GJ member did a deep dive video about them and other generation Craftsman ratchets.
Pinemarten
Washington
It might be called a "long lever" but I called it by a different name when the long lever was bumped and it would reverse on me. It did cause me to go to SK round head and round flex-head ratchets. That caused me to check the rotational direction of my ratchet (since the head doesn't indicate it by a lever direction).
A co-worker had the above pictured RHFT and I wondered, "why didn't I just buy one of these at Sears in the first place?"
bonneyman
Desert SW
Nice ole example, DavidJohnson! I like it!
You should be able to secure a rebuild kit for it. The older LLTD's had "D" slot pawls and knobs, later versions had a "hyphen" pawl and knob and were upgraded to a higher tooth count on the gear if I'm not mistaken. (Don't know the year that occurred). Either should fit your ratchet body, though the whole kit has to be swapped - no mix and match of parts.
Hope this helps!
D
So great news, I still don't have a solid answer on what model it is as per my above response. I did however take it apart to see what was going on inside of it. to my surprise nothing was broken. That being said it was dry and a bit crusty in there so I cleaned everything well and reassembled it making sure to lube it up with super lube during reassembly and it works like new and is as smooth as butter!
