Tracking down the exact same set today, complete and in decent condition, 25 years later, will be difficult at best, especially with a large set. Changes to their sets were relatively frequent compared to open stock. You might find it easier to go after similar one or more similar smaller sets, especially of the sockets, that augment each other to recreate the one in the photo.
The Craftsman socket and wrench sets from this era in blow molded cases spanning the very late 1970's to mid-1990's are quite good. The plastic blow molded cases though don't have quite the long term durability of the tools inside them. I have my father's 1/4" SAE set in blow molded from the very late 1970's - early 1980's. One of the two case latches failed long ago and the other is about to give out even though it's not been used in the past 25 years. I've been considering replacing the case, not with another blow molded though, or using pop rivets to replace the thin snap fit latches with different ones. I'm not a big fan of blow molded cases for other than things like torque wrenches.
If you're Jonesing for one of these sets, find a vintage catalog circa 1992 and get a Sears stock number from it. You may have to drop back to one circa 1985 as well. Use that in Google to seek the stock number which will be similar to format currently used. Some of your competition will be Craftsman tool collectors scouring the countryside for USA made Craftsman.
In the back of your mind, though, if your primary goal is a usable set like that one for the car trunk, consider what's currently out there from other companies. Current Craftsman are decent tools, but they're not what they were from that era and they're overpriced for what you get.
John
