help in identifying this vintage tool
BuffettFan
Central Illinois
Not a very big picture, but looks to me like a Big A$$ drill press. change spindle speed by the belts on top, swing the round table out of the way, raise the column up and down with the crank on the right side for large parts. Very heavy duty for sure.
jessesandy
Upper California
Looks like it used to be a vertical turret milling machine but the work table/x-y feed mechanisms are gone.
Or, x2 on "just a big a$$ drill press".
BuffettFan
Central Illinois
I was able to blow the picture up. The spindle and quill don't look nearly heavy enough for milling, but it sure is overkill for an ordinary drill press.
Unless you need to drill some monstrous holes in some hellacious material, I'm guess $20 for scrap!
olysteve
You'll never wish you had a bigger drill press,,,,
Sent from my XT1585 using Tapatalk
cvairwerks
Within hearing distance of Texas Motor Speedway
Probably an Edlund 2B-8. Upper section uses a box column and ways, while the lower section is a cylinder. Should be about an 18" capacity, 1hp drive. You could probably put a 3" bit in the chuck and run it thru a couple of inches of stock with no pilot hole. :lol:
Marctrees
TX/LA border - Toledo Bend
I make cribbage boards in various State and other shapes.
Bass fish shape, round, Chevy and Ford logo shapes, etc.
So I need to drill ALOT of holes.
So now I am actively searching for the "big brother" version.
At least that, or something larger. Marc
