nicksnothereman
I'm a DIY'er and looking to replace my old 9.6v Makita 6095D cordless drill since the batteries no longer hold a charge hoping you guys can help.
Most important wants:
Compact
Lithium-Ion batteries
Light weight 3-4lbs the lighter the better
Built-in L.E.D. light that illuminates the work area
Think I would prefer battery Pack over stick battery but would consider either
Open to either 12v or 18v
Open to either 3/8" or 1/2"
Powerful enough to not run out of steam drilling holes or screwing into hard wood
Comfortable grip
Good chuck
Built to last
I've been looking online at the Dewalt DCD790D2 and the Bosch DDS182-02 mainly because of the brushless, 18v, 2.0Ah, compact and 3.5 lb weight. By the way I don't know what Milwaukee or Makita has that are comparable but those brands would also be fine.
That being said the above models are really more than I'de like to spend and may be way overkill for what I really need considering what I'm used to. I will only use it for DIY projects but just want a good one that will last and will consider any cheaper models/brands/volts. Any suggestions?
Is there any difference in charging power using stick batteries vs battery pack? Do drills with battery packs tend to have a more comfortable grip?
Get a plugged drill and an extension cord.
Okay...since you want cordless get a dewalt if you like it. People like the milwaukee fuel stuff. The only cordless I have is some generic **** I paid under 5 bucks new (actually not **** but **** to other people).
Stick batteries would be weighted better volt to volt. The thing is...you don't really need anything fancy which is why I said to get a plugged model (much cheaper last a little longer).
You can refurb those nicd batteries (assumed that's what you have) btw but probably nothing you'd want to do. You know drills have a chuck not a square drive, you talking about an impact driver? But then again you mentioned "chuck".
Maybe just go to home depot and buy whatever has the best warranty in your price range (18v). 12v don't touch...
