I'm in Vancouver, BC, so similar climate to Seattle. Mostly rain on fairly mild winters and not too hot summers.
I have finished a new garage recently. One level 24'x25' with hip roof. It got wrapped in Tyvec and then 3/8" rain screen strips applied all around to shim out the Hardieboard siding. Bug nets installed to prevent bugs to get behind siding. Also vented vinyl soffits installed. Then I insulted the walls with R14 and ceiling R28, also making sure rafter vents installed. 6mil vapor barrier installed and taped and top and bottom wall seams sealed with acoustic sealant. Drywall in a few months....
There are windows on south face and sun exposure is on south wall and west wall.
I've heated the garage to about 10-14'C.
Now after one recent sunny day I came into the garage and noticed condensation on inside of vapor barrier on about upper third of south and west wall ( the ones with most sun exposure). I promptly cut into vapor barrier near top of wall to vent this moisture out. Never had an issue on any other day? What gives and what should is check or do?? Framing and sheathing was totally dry during construction and roof has no leaks.
