lilscorpion
I’m attempting to wire up a contractor to an electrical delay relay but I’m attempting to interpret the import schematic that was provided. It’s not intended for a novice I guess and I’m new to machine control wiring. [emoji12]
It’s a fairly simple contractor. L 1-3 for “Line”, T 1-3 to “Load”.
A1 and A2...is what I’m attempting to figure out.
It’s a 2 wire setup - will control a 2 hp motor. This is the schematic.
Looking at the module, A1 and A2 are clearly signal wires. Load and Line are clear too...conceptually. I don’t understand the switch in the lower right-hand corner and then how they connect to the L’s and T’s in the middle. So basically I can really only guess which is dumb. Input I have hot, neutral, and ground. What does the switch symbol mean? Are the signal wires A1 (+) and A2 (ground)...making L1 and T1 both (+) and L2 and T2 (ground) with no neutral required?
TIA, Matt
TIA, Matt
