Help making Hydraulic hard lines
tweidman
Ackermanville, Pa.
I am adding hydraulic steering to my tractor, and I need to make some hydraulic hard lines. I have no idea where to source the lines and fittings.
I also don't know what tools are need to flair or bend the lines. I think they are 3/8 lines.
Does anyone have any experience with this type of work?
Copymutt
Colorado
Decent double flare tools and tubing benders are available from most any auto parts supplier.
Its critical to get flares deburred ( especially for brake lines). Your need sounds very straight forward. Support any lengthy run in cushioned clamps to prevent work hardening from vibration. Old tractors are fun projects!
msharley
Central Pennsylvania
A "Parker" bender is of good use.
There are several "flaring" types & tools (make sure to get the right one for your application)...
Some on fleabay... https://www.ebay.com/sch/i.html?_fr...m570.l1311&_nkw=parker+tubing+bender&_sacat=0
Hope this helps
msharley
You got that right!
T
tweidman
Ackermanville, Pa.
Hydraulic tubes can be had at suppliers. Bending tools and flaring kits go to the high end. Hydraulic tube is tough stuff and will break cheap tooling.
Suppliers? What type of suppliers am I looking for, would a napa carry something like this, or do I need a specialty shop that deals specifically with hydraulics? Is there an online source?
Spareparts
Lansing Ks.
The cheap way to do this is get everything mounted where you want it and take round rod, coat hanger,gas welding rod and bend
it to the shape you want the tube to run, mark where to transisition to rubber hose and that length and the type and size of
the fittings you need. Specialty tools for hydraulic bending and flaring is expensive and more than likely when you are done with this project they will be just take up space in the tool box. You are dealing with a lot of pressure and the last thing you want to happen is a hose or fitting to rupture and spray you down with HOT hydraulic oil, it happens.
Meleon
can't help with the bending, but I've used these with good success.
Versil-Flare Tube Fittings. they create there own flare as you install them. They claim you can uninstall and reinstall several times. I haven't needed to test that yet.
3/8 stainless steel hard lines is what I used them on.
BigMike782
Some years ago I put a loader on a small tractor and I used Weatherhead Ermetto compression fittings and bought hydraulic rated tubing from McMaster Carr.
boom_bap
Idaho
I just installed a transmission cooler and had to run new 3/8 lines. I used 37* flares and JIC fittings from a local power fluid shop. Go on the Parker website and find a local distributor if you don't want to order fittings from McMaster.
De-burring Tool: https://www.amazon.com/dp/B0BY3HRRV2/?tag=atomicindus08-20
Flaring Tool: https://www.supplyhouse.com/Ridgid-41162-Model-377-Precision-Non-Ratcheting-Flare-Tool-3-16-to-3-4
Cheap Bender (Use pipes for leverage on the handles): https://www.summitracing.com/parts/SUM-900675
3/8 Hardline: https://www.summitracing.com/parts/SUM-220138
Tubing Cutter: https://www.amazon.com/dp/B001P307PO/?tag=atomicindus08-20
I have no idea if that is safe for your application, but you should look at what the fittings are rated for and what your lines are rated for and what PSI you need to safely operate at.
garfunkle24
Saskatoon, Canada
Bear in mind that some materials (most notably stainless steel) will work harden if cut with a tubing cutter and should be saw cut to prevent cracking when you flare the end.
86turbodsl
Socket weld jic fittings aren't too expensive, then you don't need to buy heavy duty flaring tools. Not sure how available the seamless tubing is.
Firebrick43
West central Indiana
Parker, imperial, and ridgid all make excellent hand benders, I have some of both.
My favorites are the ridgid roller benders 3/8 is 606 but the shoe bender works well to just takes more force.
Ridgid shoe bender would be 406
Parker roller bender PTB-6T
Parker shoe bender would be 6-2829
Imperial 364-FHB06
I purchased mine on eBay for Pennie’s on the dollar compared to new and have used the professionally to bend thousands of feet of hydraulic tubing without issue.
I would suggest a good roller flaring tool. I find flaring tools that make the flare by brute force of shoving a cone into the tube can make uneven lopsided flares.
I use a ridgid 377.
I really don’t care for the imperial 437FB flaring tool but it will work
The imperial 447F is more akin to the ridgid and a good tool but is stupid expensive
A nice shaviv or noga deburring tool is nice for the inside. A fine flat file works well for the outside edge deburring. I use a noga 1700 to do the OD of smaller tubes but it’s not necessary
I buy my tubing and fitting at my local hydraulic shop.
Firebrick43
questioning if 3/8" cupronickel would be rated high enough.
Ease of bending is my reasoning.
Bigger stuff doesn’t bend correctly and sort of collapses if you don’t use some kind of bender. The biggest downside is that hard tubes many times on mobile equipment uses hard lines in areas to prevent min or things brushing against it from damage. And the cunifer is very soft.
Firebrick43
They don’t create a flare, they use a special ferrule that bites and seals on the tube like an EO type ferrule. The end of the ferrule is what seals against 37 degree JIC/AN fitting and not the tube itself.
Rockable
Oak Ridge, NC
Find your nearest ParkerStore. They will have all you need and, if it's a good one, they will make the lines for you. If this is a "one and done" job, it's hardly worth it to buy the tools needed to do it right.
Hydraulic flared fittings are 37 degree, not 45 degree and definitely not double flared. The steel tubing is hard to bend with hand benders if it's bigger than 3/8". Don't use CuNiFer tubing, it is not rated high enough. Ask for seamless hydraulic steel tubing.
e015475
Show Low and Mesa Arizona
I use a Parker Rolo-flare tool - easiest and most consistent 37 degree flares for hydraulics (JIC)
I order all my fittings from these guys
They'll even sell you all the hose/fittings, you cut the hose to length and clock the fittings and send them to you and they'll crimp them and send them back
