Help me build up my toolbox
cptzippy
Leavenworth, KS
Relatively new home mechanic. Started with basic maintenance on my wife's SUV a couple of years ago and now have a 1994 Jaguar XJS that I'm bringing back to daily driver status. I had very little tools when I started and have been slowly building up to meet challenges.
I have pretty complete sets of ratchets, sockets, etc in 1/4, 3/8, and 1/2 inch. Got screwdrivers (including pozidriv for the old jag), combination wrenches, ratcheting wrenches, and a multimeter. Probably missing a bit or bob here and there.
About to tackle the rear brakes (outboard) and the rear suspension bushings on the old Jag as my next projects.
So what tools would you guys recommend me looking at getting next?
Mr Ratchet
I would start with a decent impact driver and a set of deep walls in STD and metric. Some good hammers (ball pean) from CM and maybe a set of pry bars.
Matt018
I will just answer that and yes you are right cptzippy, Looks like your new here, Welcome. I would also recommend getting some harbor freight specialty tools and also check out there deadblow hammers, I have a 3lb and it rocks. Also they have some brake tools that you may want to pickup, like a disc brake compression kit like with the different faces, And also maybe a digital calipers set and also a punch and chisel set to go with the hammers would come in handy.
C
cptzippy
Leavenworth, KS
Thanks for the replies.
I actually have a digital caliper set so that's good. I'll look into the disc brake compression tool. Did some looking at hammers and man is there a lot of different kinds and makes.
shoturtle
Frankfurt AM
I would add some allen and torx sockets in 3/8 and 1/4 drive. I would get a standard allen first, ball heads are nice, but you can not crank them as much as the head can crack.
C
cptzippy
Leavenworth, KS
Yep, can think of at least one place where these would have been handy so far. Got a 7mm allen drain plug for the ****** on the jag I couldn't get off with just a small allen wrench.
concealer404
Definitely full allen head set. I don't use them often, but the 1-2x a month i might need one, i'm glad i have them all. :p
You didn't mention pliers/vice grips. You'll want those.
Pry bars.
You have an early 90s jag, you'll want wire strippers, a nice soldering iron, a big connector kit, and a bunch of wiring. :lol_hitti
shoturtle
Frankfurt AM
a nice set of stubby is always useful in tight to reach area. The northern tools sets are very nice and not super expensive.
6-Speed
A set of breaker bars, 18" and 24" 1/2 drive are handy. Suggest a few torque wrenches to cover multiple ranges from low torque to higher torque such as lug nuts. A good caliper tool set will help with the brakes.
concealer404
Not too bad so far but my multimeter got a workout the first couple of months i owned it.
Heh i bet! The worst part about these really is just fixing the little things the PO didn't bother with. Once you get caught up, they don't really deserve the bad rep they get, in my opinion. :)
C
cptzippy
Leavenworth, KS
Have a CM 1/2 inch beam-style torque wrench 20-150 ft/lbs. Need to get one that get's the 10 newton meter for some of the engine bolts. Shoturtle - when you say stubby I'm assuming you mean wrenches?
C
cptzippy
Leavenworth, KS
The Jag has been a reliable daily driver for the last year. Had a brake light issue when I first got it but found a short. Got some maintenance stuff to do - ATF change, rear brakes pads and rotors, some suspension bushings are worn.
teletekman
Madera, CA
Since your building up your collection and not knowing what you have now, you might want to think about a bigger tool box to handle all the additions if you don't have one already...
C
cptzippy
Leavenworth, KS
I've got an eye on a tool box after I move. Right now just don't have anywhere to put something larger than the little 3 drawer carry that I have now.
concealer404
C
cptzippy
Leavenworth, KS
There's a hand-held kind that you squeeze the handles together like pliers and the plates force the piston back into the caliper. It ratchets. The real name for it escapes me right now and it's driving me nuts.
Anyways, it's what i like.
This isn't it, but it looks kindof neat: http://www.ustoolman.com/index.php?...cts_id=19248&zenid=2ejarblc8qahqk5lev96cllmc1
Think I know the one you mean.
Another question: since I'll need to get some 'auto' hammers as the only hammer I have right now is a stanley claw hammer I've had since college, what about the replaceable face ones? What are the pro's and con's of them?
C
cptzippy
Leavenworth, KS
Another big thanks for all the help. I've looked at both types of pad spreaders and can't decide which looks best. What do you guys think?
BajaBound
Nor Cal
Full socket sets sae & mm
Full combo wrenches sae & mm
Pliers
Ball peen and soft face hammers
Allen key and sockets, Torx keys and sockets
Screw drivers
Torque wrench
C
cptzippy
Leavenworth, KS
Any answer to the hammer question? If I just got one hammer, what one should I start with? Also realize my pliers selection is pretty limited.
NUTTSGT
Northern Central Ohio
Are these USA or China Craftsman. Haven't had luck with the couple of China CM that I've bought. They do look nice though.
Honestly, I really don't know. I can assume (USA)though. When purchasing them separately, they're Made in the USA. I was looking at some the other day at Sears. I picked up a 3lb drilling hammer, USA.
6-Speed
The HF kit is what I use, but Sunex also offers a similar kit but at twice the price; I don't know if the Sunex is any higher quality than the HF kit.
http://www.amazon.com/dp/B0015S9VRE/?tag=atomicindus08-20
abbeylives
Each of the discs in the caliper kit match up to a particular style piston. For example, Honda or VW. If you are doing brakes on a early 90's toyota, that disc is selected which then is position between the piston and tool. As you tightened the tool, the caliper piston is turned with pressure - putting it back in place. I definitely recommend a kit like this, cheap enough and allows you to handle any type of rear brake job.
6-Speed
So what do all the things in those two kits do? I'm trying to envision how they work and coming up empty.
For front brakes such as those on my 04 Odyssey, the caliper piston does not need to be turned, so I use the floating adapter, which remains stationary and doesn't turn with the handle.
For the rears where the parking brake mechanism is integrated with the disc brakes, such as those on my Mustang, you have to turn the piston while applying pressure to the piston face, so I use the proper adapter with pegs that fit into notches on the piston face. C-clamps will not work here.
pipsters
USA
They are US made, made by Vaughan
I have the set, what can I say, they are hammers. US made. Good deal.
For prybars consider these, they are made by Mayhew but much cheaper than if bought from them. Apparently they are closing them out. Too bad they are excellent.
http://www.sears.com/shc/s/p_10153_12605_00947410000P?prdNo=4&blockNo=4&blockType=G4
Stuff4Toys
SW Florida
idoitproject
Elk Grove, CA
You can rent this set from Autozone:
http://www.autozone.com/autozone/ac...-Tool-Set/_/N-264a?itemIdentifier=298604_0_0_
It's about $60. You can either keep it or return it for a full refund. It's Autozone's tool loaner program. Best thing about it is that it's LIFETIME WARRANTIED. So you can rent it as needed. It is a hassle to run down there everytime you need it but you can give it a test run for free pretty much.
