Joelk
I want to modify my oil drain tank so that it will also function as an Oil Extractor.
I have an 18 Gallon Steel Drain Tank. It has a large ball valve on the top of it, that the funnel inserts through. In normal use, when emptying the tank you remove the funnel and close the ball valve to seal up the tank. You then apply air pressure to a fitting at the top of the tank and it forces oil out of a drain line.
I want to reverse the process and apply vacuum (I have a couple different vacuum pumps I could use) where I normally apply air pressure and an extraction tube where the drain line normally attaches.
I would like to install a "vacuum relief valve"(it currently has an air pressure relief valve). The tank is fairly heavy walled steel, so I am not concerned with collapsing the tank from too much vacuum, but I am concerned that 30 inches of vacuum may collapse the extraction tube.
Do they make reasonably priced "vacuum relief valves?" If so, where can I get one, and what vacuum level would you recommend?
I am also seeking suggestions on what to use for the extraction tubes.
