Crazy Legs
Hey everyone,
I bought a Sears 80gal 2 stg air compressor in 2008 and its worked great up until this last couple of months.
Long story short a "reed plate" broke in the smaller high pressure head and the pieces junked out the check valve.
I ordered all the right parts from Sears and installed them yesterday, everything worked great, it pumped up fast but when it got to 105psi the pressure relief valve on the smaller 2nd stage head popped off on every stroke and wouldn't go any higher psi.
Its never popped off before, it has a "70" engraved into the side of this relief valve and i'm assuming it means 70psi but that doesn't make any sense cuz the pressure would be much greater than that I would think.
Anyway I took everything back apart and it looked great, no issues etc. I installed the old check valve in the tank and let it build back up and as soon at it got to 105psi the PRV popped again....
I pushed on the PRV on the head to hold it in and it continued to build psi above 105 just like it should but as soon as i let go it blew off like before.
FYI, It normally shuts off at 165ish and turns on at 145psi
I'm completely lost on what could be wrong.
