Help me find a 6" wide board
HPRifleman
Member Emeritus
Wayne, IL
Not actually garage but I thought I would tap the knowledge base here.
I want to replace some fence boards that a tree has pushed through. I can cut down the tree but I am having trouble finding replacement boards. The actual dimensions of the wood is 6" x 11/16". I'm not picky on the thickness but I want to match the actual 6" width of the other boards. All the wood (I'm guessing cedar) that I find locally is 5 1/2" wide. Any ideas?
WisJim
Menomonie, WI
Around Western Wisconsin you can find a small sawmill that would either cut something to order or have something in stock. Or rip down 1x8s.
FredWanaker
NorCal
1" x 8" and rip. That will give you 3/4" x 6". If you want an actual 1" x 6" then you will need to go to a lumber mill to order it. They'll take a 2" x 8" and plane it to 1" then rip it to 6". You might see if anyone has rough sawn green lumber, often it is almost dimensional.
jkuro
If you want one inch thick board, you need 5/4" x 8" x ?', and rip to size.
Available at HD, Lowes and any lumber yard.
Skiff Builder
Southern NJ Coast
I've ripped a lot of boards in my life.
That said, I could fix what you got there with good glue (epoxy, PL Premium, Titebond II) and pocket screws ( or long construction screws). Take off the top board and move it to the bottom to help hide that gouge.
Shiftless
East Bay SFO
That‘s exactly what I was thinking. Glue it and screw it.
Apply glue, clamp in place to hold the joint tight together, run in a few screws (even drilling pilot holes to minimize the chance of splitting)
When the glue is dry, sand it a bit if the alignment isn’t good enough and dab on a couple coats of paint. You’ll hardly notice the repair. And hey… it’s only a fence.
CraigStu
Blacksburg, Va
Unless I was planning to move I'd just switch to 1x6s. I wouldn't want to have to make or order wood every time I need to repair a fence. We had a fence like that around 2 acres for about 6 years. I think the deer missed sometimes when jumping it because repairs were a lot more frequent than I expected.
bbbarracuda
Depending on how long the boards need to be, you could rip several 6” boards from a sheet of plywood. 3/4” is only 1/16 thicker
