bannerd
Long story short, the old (1979) 18hp briggs on my mower decided to let go of the valve seat. Normally you can push the seat back in and peen or drill a lock hole into the seat/block. Unfortunately this seat must have been loose for a long time as it honed the block ever so.
My plan is to tig weld around the bore with aluminium filler rod. The next step is to cut out a hole. I was talking to an old briggs mechanic and he has seen a lot of that in his years. Briggs had a tool that you would stick in the valve guide, there was a spring and you would basically bore down about an 1/2" after filler. It was turned by hand or drill.
Well I did some looking around for this tool and I don't see anything. Anyone have any ideas how to fix this? Should be very easy.
https://drive.google.com/file/d/1nMP-aqbvOS_p6BW7a208r0dDoVPLq9Gq/view?usp=sharing
https://drive.google.com/file/d/1ekbD0CaomBbRzU4dXkVqMOtoMMjwdDt6/view?usp=sharing
