Help Me Fix An Air Compressor
D45
NW INDIANA
Today picked up this little 120V, oil lubricated, portable air compressor
When I try to turn it on, there is just a loud humming/buzzing noise
The motor does not seem to turn on
The compressor is probably 5-8 years old and appears to visually be in good working order
What can I check to try to get it to fire up?
Alton
6 HP
2.5 HP
AT01204-6
Similar to this:
https://www.aircompressorscenter.or...6-gallon-hotdog-tank-oil-lube-air-compressor/
rlitman
Long Island
first check to see if the motor /compressor spins freely by hand. under the shroud will be a fan you can see if it turns. next is check the start capacitor
Yep. There's a good chance that once you turn the fan a bit by hand, you may be able to plug it in and watch it work.
I'm assuming that there's no pressure in the tank and it's an unloader issue, right? Or (dotting all the i's and crossing all the t's) the check valve could be stuck shut, so the pump can't push any air, stalling the motor.
My portable is just like that (could be the same exact one). I got it in a similar state for chump change at a thrift store in the same condition (hummed, but didn't run), and I found it tight and grinding as I turned the fan (these are direct drive, so you can't just take the belt off to check the motor). In my case, I had to take the pump apart and use a stone to remove some burrs from the cam. It's been working great for the past 15+ years since.
D
D45
NW INDIANA
Took the plastic cover off...........6 screws
The motor fan blade would move and rotate somewhat easy
I added a few ounces of oil to the fill port
Shot some WD40 on the motor shaft bushing/bearing area
The compressor fired right and ran SMOOTH
I am glad I took the time to save it from being thrown out
There was a decent amount of brown rust water I drained out of the tank
All is good. Hope it runs this good a for a few more years
