help me ID this jack
turbo6justin
Milwaukee area, WI
I have this older, I believe Craftsman jack and it started leaving a pretty good blood trail over the last few weeks. It should be pretty straightforward to replace the seals per the sticky if I can figure out what the heck it actually is. I am reasonably sure it is a Craftsman. It is at least 14 years old probably closer to 20 so mid/late 90's. I am gussing it was rated as 3 tons.
The part number has illuded me to this point. The main sticker on the top is obviousely gone. I have looked and am unable to find a stamped part number anywhere else. The shaft on the ram measures 1.340" in diameter. I have not pulled the ram to see if there is a part number on that somewhere as I am currently using this just about every day. Any ideas so I can start the search for a rebuild kit?
[/ATTACH][/ATTACH]
RECox286
South Joisey (yeah, that is part of the USA)
Hey, Turbo.
The pictures of your floorjack match mine in every aspect, so I'm
guessing that they came from the same factory, on the same boat
and were retailed in the same store. Enough speculation...
Your description fits mine; about 15 y.o. no identifing data plate,
decal or stampings. But I do have the C'man manual that came
with the jack (I'm a packrat). It is a Model 875.501152 3 ton
from China. Of course there is no rebuild kit, as there was never
one to begin with. The parts list only shows that, at one time,
there was the entire "power unit assembly" available as the only
hydraulic part stocked. The illustration gives no hint as to what
parts are contained within the assembly. If you decide to remove
the power unit for rebuilding, be very careful to not lose the two
different 'ball bearings' that are in the release valve cavity. And
if you could, I would appreciate your getting their diameters b/c
when I took mine apart they went "somewhere over the rainbow"
probably to never see the light of day again. I will refer to to PM
HIBALL, here on GJ as the resident hydraulics guru. He may
be able to supply you with what soft parts you need. IIRC, I found
that the O'rings I needed were metric, and a small metric selection
from Harbor Freight did the trick. I found a small ball bearing in my
20 year box, and it kind of works, but not the way it should.
If you could PM me back with any information you get, I would
sure appreciate the effort.
Good hunting
Uncle Bob
