Help me ID this jack.
686sx
PA
Can someone help me identify this bottle jack. I could not find any identifying marks. The ram measured 2.363"(60mm) in diameter. Would like to find a kit for it. Thanks
686sx
PA
It looks that way to me too but it doesn't leaks there. Just leaks around the seals and the rubber plug.
686sx
PA
If i cannot ID it...What next? ...If i take take it apart .. can i get seals from measurements?
mikegt4
sw ohio
I had an old 12T bottle jack that needed seals but the label had been damaged beyond any possibility of reading it. I took several photos of the jack with particular attention to casting numbers and e-mailed them to Blackhawk. They responded with a positive ID and recommended rebuild kit. The kit consisted of high quality parts, not just some cheap O-rings. I reassembled it and it has been working like new for several years.
https://www.blackhawkparts.com/
BTW, it turned out to be a Lincoln, re-badged as a NAPA, good old USA made iron.
686sx
PA
I got another one. It looks almost identical to the first( one looks like a knockoff of the other) They both have that brazing ( one looks better than the other) so now i think it must have to do with how they are built. Still no clue about the make though.
