Help me ID this Walker Floor Jack Model
jreb10
Westby, WI
I bought a Walker 4 ton floor jack at auction recently. It does not lift, not that I would trust it even if it did. I want to rebuild it but I am not sure of the model number to get the right kit.
It does not have a plate at the base of the handle. It does have a worn serial number strip there, and what is perhaps a casting or part number below it?
Any help is appreciated.
Hiball
Missery
J134 or Early 93657 series, regardless should be the same kit from most suppliers, definitely will be from the supplier in my signature. Wouldn't hurt to inspect the inside prior to buying a kit, just in case there is some rust issues that will require machining etc.
J
jreb10
Westby, WI
Thank you Hiball. I think it is an early 93657 as the serial number starts with 657. I will be reading all your advise posts to help me through the process.
