The existing 12 year old 2 bulb T12 U-tube troffler fixture installed in my kitchen lights occasionally, at best, if you leave it on for 5+ minutes. I have installed new bulbs in it with no appreciable change in function. Obviously, it needs a new ballast. If I am swapping out the ballast, I'd like to upgrade the performance or reduce the energy consumption of this light fixture if possible.
T8 U-tubes are available, so can I simply swap in a T8 ballast and two T8 U-tubes and get energy savings and a functional light again? This light tends to stay on for hours at a time, so reducing this fixture's consumption would be nice.
Or, should I just stick with the T12 U-tube for some reason, and simply replace the ballast?
