Back story: POCO has decided to work with me to improve service reliability for me and my neighborhood. This fall they are going to feed my house from the main road, removing the 125' service drop theough the back yatd that is tugging on my house causing some structure issues. Next spring they are going to re-route the main feed for the neighborhood out of the woods behind me due to the continued service interuptions and lack of vehicle access.
So in a few weeks I'll have a new pole at the road and one halfway down my driveway. It looks like from there it will be about 125' total to the house panel, 90' underground.
Option A: run 200A service down pole and underground to the house, need a new meter pan. Can use dual meter pan and maintain my reduced rate for the h2o heater.
Manual generator interlock is at the house.
Future shop (2 years away) would be fed from house panel.
Option B: run 200A service down the pole to a new meter/main on a pedestal next ro pole. Run 200A 4 wire to house. Need to move grounds over and DE bond.
Loose the redused rate h2o feed, but already planning an on demand propane heater at some point.
Genrator interlock or ATS can be here, which is also close to my bulk propane tank, or at the house.
Future shop is then a 4 wire sub from the pole
Difference in distance to shop is maybe 50 feet.
Which scenario seems better? What wire should I run undergoing in condiut?
