Help me size my compressor needs
NBN
SE Tejas
A few years ago I bought the shop where I was working when the owner decided he was ready to retire.
We were a small shop doing classic car restorations and had 3 guys performing the typical jobs found in this type of work. We had a paint booth, large blasting cabinet, and the typical air tools. I've got an 80 gallon Quincy with an extra 80 gallon tank for volume. The setup worked well and didn't seem to overwork the Quincy.
I'm now looking at downsizing the shop and relocating, becoming a one-man operation. I'll be loosing the booth and won't have the extra employees using air simultaneously, decreasing my air needs. Cars and parts will still be painted - on a smaller scale, the blaster will still be used as needed, etc.
As I'm planning on getting a new compressor, what's the thoughts on sizing my new purchase? Single 60? Single 80? I'm thinking the 80+80 as before will be a bit much.
PoorUB
Fargo, ND
5HP, two stage, 80 gallon. Tank size is somewhat irrelevant. 60 or 80 gallon is what you will typically find on a 5HP. A larger tank has the pump running fewer start/stop cycles, but long off time.
5HP is the minimum for sand blasting. Most air tools can use a bit smaller compressor. I went from a 3HP to 5HP. The 3HP was a bit short, the 5HP unit keeps up with my demands easily.
firebirdparts
Kingsport, TN
I think technically you do need a 5 hp 80 gallon (like say 15 CFM). For all of us one-man-shops, there's a possibility you buy a $500 compressor and just deal with it. There used to be a big jump in price from 11 SCFM (like say 3 ish hp) up to whatever is the next size up. that is a little less of a gap today.
I know $500 compressors don't cost $500 anymore but you get the idea. You technically need a 5 hp but you can do whatever you want to do by using a 3hp and smoking cigarettes once in a while.
Oil free produces a lot less air per hp FWIW. And also a lot noisier.
  • Like
Reactions: NBN
TJay
Muskego, WI
As previously stated, almost any 2-stage 80 Gallon should fit your needs perfectly.
Since I work with IR compressors, my choice would be the 2340N5-V.
  • Like
Reactions: NBN
pcmeiners
Tank size is not the issue, cubic foot per minute is. It will be a foolish move to dump the Quincy if it puts out approximately 17 cfm or more (5 hp or more) which is minimum for blasting.... very foolish.
BillK
Beautiful Southern Maryland
Except the guy is painting cars and using a sandblaster....
I have painted 2 cars with my 50 year old 2 HP 20 gal Craftsman :) It is Identical to the one in this thread:
I have even done some blasting with it but only small stuff outside at home. If I was doing a lot of blasting I certainly would want something larger.
Chris_Hamilton
Honestly IMO as I do the same type of work as you do, you don't really want to go any smaller than what you have now or did have. 25 CFM is what I consider the minimum especially if you plan to blast.
PoorUB
Fargo, ND
Some of you guys are a bit nuts! I have sandblasted a lot of stuff with a 3 HP compressor. It was almost adequate for a hobby situation. 5HP and 15 CFM would be fine for most of us. I can understand if you are running a large shop and doing a ton off sand blasting that way more is better, but in the OP's situation I would recommend 5 HP, or 7.5 HP compressor at the most. I knew a guy that did sand blasting and he had set up as a stationary unit a 100HP diesel engine powered compressor, but he sand blasted pretty much 10 hours a day. He hired a couple "kids" to prep items and move things around while he was blasting.
Imatk
I have a 60-gallon Quincy QT-54. I've not painted an entire car so I can't comment on that. I have painted sections of a car without issue.
I have a blasting cabinet and it has been USED extensively.
I've never once had a hiccup blasting. No issues with air, I have a three filter setup for moisture and long runs of copper pipe... it has worked flawlessly.
I couldn't physically fit an 80 gal in my setup and was worried that 60 wouldn't be enough. It's been more than enough... for me.
  • Like
Reactions: NBN
PoorUB
Fargo, ND
Sand blasting takes a ton more air that a paint gun. I have painted cars with 3 HP and it didn't run constantly.
Chris_Hamilton
I can only comment on my experiences. I have an ALC 110 lb pressure blaster and when I'm media blasting a body or frame it runs 80% or more of the time. I have a 7.5 HP 25 CFM Champion. Im just a one man Shop abd i consider it the minimum really. Hardly nuts.:)
When you refer to manufacturers literature about CFM requirements with the ALC it's up to 35 CFM consumption with the biggest nozzle.
5hp and 15 CFM would be OK for most spray guns but marginal for alot of other common tools in a bodyshop. DA's and big air powered 8" rotary sanders to name a couple. Bigger is always better. It will make less water, won't run as often, less stress on the machine etc.
  • Like
Reactions: NBN
