junglebadger
- Joined
- Feb 18, 2022
- Messages
- 1
This is the back wall of the garage on ground floor of new construction townhome bought last year. On the other side of this wall is a bathroom and closet. I have some simple metal shelves that I'd like to hang here for storage along the line I've marked, but can't make heads or tails of the stud placement here.
Stud finder seems to confirm that there is a stud on the left side of the outlet, but then they're irregular from there on. Since I can see the spots where the drywall screws are located underneath the mudding, I've also tried measuring the space between each set of screws (assuming those panels are screwed directly into the studs) and those are also irregular. Even more confusing to me is that the line of screws above the stud are oriented as if they're screwed into a stud on the right side of the outlet, which my stud finder does not pick up. You can see I've drilled some holes here and there, but I'm not trusting my ability to feel the difference between stud and space with the small bit I used, I may go back with a larger one once I get desperate.
Thoughts?
Thoughts?
