FigureItOut
I've been wanting to build a platform for working under dash similar to, but better than the ones pictured. I have a couple general ideas in mind, but the one I prefer, I have some doubts about and I wanted to get opinions as to whether it could be built stiff enough, and still compact.
Picture a platform like above, only instead of the cross piece resting on the ground, there's four swivel casters. The whole thing ends up shaped like a tall "U", on it's side, such that you can roll into position and adjust, while remaining in the same position on the platform.
The bottom shouldn't have any problem sliding under the car, so the footprint can be the same or even larger than the platform, for stability. The platform height must be adjustable obviously. My biggest concern is that there's no way it's going to be stiff enough to hold me up, and hold the platform up off the car's threshold.
Alternatively, I can do it almost just like the ones pictured, only with two swivel casters at the bottom support, and one swivel caster mounted basically directly under my head.
Any thoughts on my general ideas, or other ways to do this that come to mind?
Sent from my XT1575 using Tapatalk
