hoffman912
Hey guys,
I wanted to get some opinions on some garage heating units. I have narrowed down to 3, but I cannot make a decision. cant pipe in gas heat, and my garage only has 30 amp. So these are it! I dont want to do a torpedo unit so please dont recommend it instead.
Option 1: Kerosene unit
https://www.tractorsupply.com/tsc/p...0-btu-convection-kerosene-heater?cm_vc=-10005
23.5K BTU
portable
99% efficient (indoor safe)
2 gal = 12 hours
Efficiently heats up to 1,000 sq. ft. (not sure how when its less BTU than the propane options.. but it heats 360* around it, rather than just outward in one direction)
Pros:
cheaper cost for the unit @ $129
No additional equipment needed - fill and fire right up
Portable (can move anywhere in the garage i would want to work
indoor safe so i wont kill myself
Cheaper to run - $4/gallon = $8 for a 12 hour run.
easier to have spare fuel on me
-can have a gas can full and refill if i run out,
-gas station with kerosene is open longer/later than store to fill up propane tanks
Can use in the house for emergency heat (though we have a generator to power the boiler so not a big deal)
Cons:
Storing out of the way is kind of a PITA
larger footprint
would only use kerosene for this, so would have to have a jerry can somewhere full of it (and whats the shelf life for kerosene if i have it laying around 8 mos of the year?)
Option 2 or 3: Mr. Heater 30,000 BTU Vent-Free Radiant Propane Heater OR Mr. Heater 30,000 BTU Blue Flame Liquid Propane Vent Free Wall Heater
first any one know the difference between the blue flame vs radiant? pros cons there? I cant identify the difference or pros or cons between the two...
a) Radiant
https://www.tractorsupply.com/tsc/p...vent-free-radiant-propane-heater?cm_vc=-10005
b)Blue flame
https://www.tractorsupply.com/tsc/p...id-propane-vent-free-wall-heater?cm_vc=-10005
both have the same specs
more expensive $200
30,000 BTU
Heats up to 750 sq. ft
Thermostat for automatic temperature control
Automatic low oxygen shut-off system (ODS)
20 lb tank of propane = 14 hours
both have pros
can mount to a wall (ie, no storage concerns, but takes up wall space)
or can sit on feet (somewhat portable - but skinnier and easier to store)
20lb bottle of propane can be used for the grill in summer (ie no worries about extra cans of fuel sitting around - will get used year round!)
Propane doesnt go bad as quickly as kerosene (actually never heard of propane going bad) - again shouldnt be a problem considering we have a propane grill
Both have same cons
not portable if wall mounted
More expensive for the heater by about $70
would ALSO have to buy a 2 stage regulator ($40)
would Also have to buy the tank lines for it ($26)
propane is $3.19/gallon. Would be more expensive per unit. 5 gal = 20# tank full = aprx $16 per 14 hours.
going to the store to fill up propane tank = bigger PITA than filling up a jug of kerosene
could have extra (or larger tank of propane), but that takes up more space
stores that refill propane not open as long as
In Ohio it gets pretty cold. My garage is NOT insulated. I would probably work in the garage when its as cold as 20* out if i had heat in it, unless it was an emergency repair and i had no choice (shouldnt be in that position really since i work from home and we have 2 daily drivers)
my goals are to get it up to a reasonable comfortable working temp. 50s/60s.
I do have two separate rooms. a 2 car garage (specs in my signature) and a smaller side room that is more storage and wouldnt be used for working in during winter (at least right now)
of the two options. what would you do?
23.5K BTU
portable
2 gal = 12 hours
Pros:
Cons:
larger footprint
a) Radiant
b)Blue flame
more expensive $200
30,000 BTU
both have pros
Both have same cons
