My Fan Delay relay started shutting my blower fan on and off very erratically, so I ordered a new one and went down to the local motormart and picked myself up a relay so I could bypass the original circuit board with the imtegrated time delay for the time being. Anyways The fan works as it should now and the heat pump comes on but the auxiliary heat coils wont come on now. I used the ground and green (t)on the coil of the relay and the reds (1 and 3) on the switched part of the relay. I taped up red (a) white (6) and blue (ground 4). Now Im no wiring expert by any means, but If I look at the diagram it shows me 6 and 4 get connected via a relay, but if i check the white wire (6) it has 24 volts to it. so is this right? can you connect a hot wire and ground together? (i tried and the aux heat comes on) so Im just wondering what they are doing in this diagram and if i shouldnt go get me a dpdt relay instead of the spdt relay so i can make that connection via a relay if it is right. My heat pump will more than likely get us thru till new board gets here but Im just curious now. Sorry if this is confusing and thanks for the help.
