Help mounting 3/4" conduit to hollow wall
Roothawg
Mustang,OK
I bought a new compressor and started to lay out my conduit this weekend. The problem is, I have a steel building and there is no structure where I am wanting to mount it. I covered the insulation with galvanized corrugated sheet material, bu the span is too far apart. I need to mount a J box and support about 8' of conduit.
Do they make a wall hanger similar to plumbers strap, but more substantial? Like a track of some sort?
I found this, but I am not 100% sure on how to use it. I THINK I know, but.....
https://www.grainger.com/product/GRAINGER-APPROVED-Slotted-Standard-1-5-8-x-1-45YV29
Thanks,
Root
mike93lx
Richmond, VA
Unistrut, what you linked.
You should be able to get 10' lengths. Lookup their catalog, you'll see hundreds of options for mounts
rlitman
Long Island
I assume it is designed to mount vertically?
You use the holes to bolt it to your structure, perpendicular to the pipe run, and then use special pipe clamps to secure the pipes to it.
BillK
Beautiful Southern Maryland
How about a picture of where you want to mount it. The pipe shouldnt have to be supported along its entire length. I am thinking one support at each end and one in the middle. I might be wrong but that price for Unistrut looks awful high too. Check with a local electric supply house first.
rlitman
Long Island
HD carries it. I just paid $20 for a 10 foot galvanized stick of the thin (3/4" depth) galvanized strut channel. The yellow stuff is a little cheaper, and the 1-5/8" tall is a little more expensive.
It cuts easily. I brought a hacksaw with me to the store and cut the 66" piece I needed on the shopping cart to fit it all in my car.
R
Roothawg
Mustang,OK
Thanks. I found some at Lowe's in my home town way cheaper.
One end goes into the fuse box, the other will be supported on the end with the J box. I don't even need the J box really. I bought a 6' conduit whip but I don't think I want to cut and tie the ends together. I like the idea on no breaks in the line. The wire from the box is long enough to reach the compressor in one continuous run, so I just need something to make the transition from the PVC flexible conduit to the end of my EMT conduit.
I don't have any pics. I'll have to snap some tonight, if I get time.
Honestly, I need the shortest stuff they make. It makes it easier to get under the conduit. I also have some previously mounted 1/2" zinc water line I use for shop air. It needs supporting as well. I'll try and capture all of it with 2 sticks. If I am lucky I can cut one in half and get what I need. Just have to measure tonight to make sure.
Bopbop
Savannah,Ga
Search in the Grainger website site for a B-Line conduit clamp which is listed as their item #4RHZA, model number BL1410. I used these to mount my aluminum airlines to the sheet metal panels in my shop. Home depot also keeps these in stock in their stores.
The unistrut works real good but cost more. Around here home depot also stocks it and the clamps
Terry D
St. Louis, MO.
One hole straps for EMT or Minerallacs ( also called minnies ). Minnies holds the conduit 1/2 inch off surface, no need to bend a box offset in the conduit to bring it in the box. If you use a one hole strap, you will have to bend a 1/2 inch box offset to bring it in the box. I personally like one hole straps and box offsets. Use sheet metal screws to attach everything. Unistrut would be overkill for that small of conduit and that short off run, just my opinion.
sberry
Brethren, Michigan
Sheet metal screws are self tapping,, I know we are talking about drillers. A lap screw, I forget the tech name but it has a big barrel designed for sheet to sheet. Put them in laps where it's double thickness. Even use a 2 hole on the end, even common screws 10 or better works. Can even do this 1/2 pipe,,, believe it or not.
Bert_
NW Iowa
Self drilling is different than self tapping. But agree a common sheet metal screw will work.
You're right. The terminology is often interchanged but not the same. Self drilling is the wrong choice. A sheet metal screw is fine.
teamextreme
Lakewood, CO
You guys are in the weeds about fasteners. I'm more concerned about this convoluted description of the conduit run. Can you post some pics or give a better description? This sounds all kinds of jacked up.
Are you running a continuous conduit from panel (not a fusebox) to receptacle box?
Are you using multiple types of conduit?
Is the conduit just short sleeves for protection of romex?
What kind of wire are you pulling?
If you are using PVC, are you running a ground wire?
Jim greengo
Behind my house
Don't use self tappers on sheet metal. You need a pointed sheet metal screw or they will strip.
The thread is what holds it in the sheetmetal,the point of the self tapper just starts the hole is all.
It's pretty tough to start a sheet metal into the heavy gauge tin used inside buildings without a pilot hole or a self tapper.:beer:
Terry D
St. Louis, MO.
Sounds like he is running EMT from the panel to a J-Box and then using a sealtite whip to go from there to the compressor. I hope he is using THWN and not Romex in the conduit. As long as the panel is only 8 ft away and in sight, the circuit breaker would serve as the disconnect
mike93lx
Richmond, VA
Romex is fine in conduit. Thhn is easier, no question. But if it is indoors and not a wet location romex is kosher
