I only know a little about electrical but willing to learn. Some of my terms my not be correct but I'll try to explain the best I can.
I only have one space left in my breaker box. I need 2 spaces to install my 100 amp breaker for the garage sub panel. There are several circuits that could be "doubled tapped" or install a tandem breaker. The box is cutler-hammer, there is 1 tandem breaker in there so I assume I can use another to free up a space. Either way I'll need a new breaker. I don't feel like the smoke detectors and door bell need there own 15 amp circuit each, They could be put on the same breaker. I started reading how to install tandem breakers and double tap breakers and something came up about "multi feed" and I couldn't follow what I was reading. Something about shearing a neutral but using but using different sides of the main feeds. Well all the neutrals and grounds look to be connected in the box on each side then have a bar connecting both sides together anyways. Do I even need to worry about that?
My plan is to install a tandem or double tap breaker in the space labeled "chime" and add the "smoke" hot wire to that space as well. Then move all the breakers up one space to install my 100 amp down in the bottom left 2 spaces.
Next is the "hot spot" issues. My hvac system has 4 breakers? 3-50 amp and 1-30 amp. I'm pretty sure the 2 lower 50 amp on the left are for the electric back up heat. It's a heat pump system that is pretty efficient and I have never notice the emergency heat coming on. I don't think it will be an issue. Please correct me if I'm wrong.
Next I want to use the knock out on the lower right corner to install the conduit going to the garage. The panel is on an exterior wall and I can run the conduit right out the back down into the ground.
The sub panel is 175' total wire length from panel to panel. I plan on using 3, #2 gauge copper thwn and 1, #6 thwn ground, burried in 2" conduit with 100 amp In the main panel. I know I could go cheaper and run the 2-2-2-4 al mobile feeder with a lower breaker I'm just scared about the aluminum wire, corrosion, connections and old stories. I want to do this once and plan on living here for the rest of my life. I'm 28,so hopefully I have some years ahead of me.
Please pick apart my plan and let me know where in messing up.
