Help! Need a socket driver hex ball 10 mm, extra long (160mm)
Geurt
The Hague, Holland
I need a socket driver with:
- hex 10 mm
- ball end
- extra long hex part, at least 160 mm. or longer
- drive doesn't matter (1/2 or 3/8)
Can't seem to find a brand that sells one. So if anyone has a tip.
example:
marcone
Romania
I am guessing this is needed for a special job. What you can do is take a long L shaped Allen, cut the short piece off and mate the long piece with a 10mm socket. It should to the job.
G
Geurt
The Hague, Holland
Just a thought, maybe make one? :dunno: Quite a few companies make long ball end hex keys, how about just cutting the short end off and placing it in a driver that you already have?
Sorry, it's the only idea I had.
Chrome version
http://www.wihatools.com/600seri/669Chrom_mm.htm
Here is the black version, 221mm, $6
http://www.wihatools.com/300seri/369mmserie.htm
Thanks! That was the back-up idea. But considering the intended use, a ready made - off the shelf unit would be best.
Plasmatic
Slightly shy of your length spec at 6" (=152mm):
Bondhus 43876:
http://www.micro-tools.com/store/P-B43876/10mm---Ball-Bit-x-6in--With-38in-Dr-Socket.aspx
305mm blade ready for insertion in a socket:
Bondhus 3676:
http://www.micro-tools.com/store/P-B03676/10mm-Ball-Tip-Hex-Blade--12in-Long.aspx
The same in 303mm length:
Bondhus 0476:
http://www.micro-tools.com/store/P-B00476/10mm-Ball-Tip-Hex-Blade--Long.aspx
The same in 229mm length:
Bondhus 0176:
http://www.micro-tools.com/store/P-B00176/10mm-Ball-Tip-Hex-Blade.aspx
Shop around and you might find better prices, not sure.
