I had a Morton building put up last winter and had them do the concrete. They did not put anything for expansion around the perimeter, but they did put in thermax type of insulation under the floor around the perimeter of the building.
Dont forget to put good vapor barrier under the concrete. I also had mesh put in along with fiberglass reinforced concrete. I also had the electric run in conduit as well as an empty conduit run to the house before the concrete was poured for future needs like cable TV phone, etc.
I also had to have my floor poured before final inspection because it was it showed a floor in the approval. I had to wait for the floor because of the cold winter. The inspector gave me some type of conditional inspection so I could use the building until spring, then gave me a final after the floor was poured. Luckily it warmed up and I got the floor poured before the permit expired in the spring. but the inspector said I could get an extension that would give me more time if I needed it. If you are not in a position to get things done now see if you can get an extension.
Chris
