Hi everyone my name is Josh
I recently obtained an old compressor. I can't tell the model number. I can tell its a Charge AirPro made by DevilBiss made in 94. It is a 12 Gallon tank with a Ge MO-9045 motor. 3450 RPM not sure the HP. I think 4HP but not sure. Tank has a tag welded to it that says 125 max PSI at 350 degrees F.
My question is what tools could be used with this. I would like to run a basic impact and gravity feed spray gun. Do you all think this compressor would run these tools? It needs a new line ran fro the motor to the tank, but would like to figure out if it will work.
Thank you all.
Thank you all.
