Help Needed: Air Compressor Discharge hole thread broke.
DayMack
Hello, thanks in advance for reading and possibly helping me out!
I have an air compressor where the discharge connecting point thread is damaged. It can't be tapped due to about half of the threads being broken off. I have been reading around and I think I need to drill out the remaining threads and then replace the threads with some sort of kit?
Any help is much appreciated, thanks!!
joe49
Tonica, Il
Often with pipe thread you can tap the piece deeper. The thread is tapered and will cut new thread were it is missing, as you tap it. If you are not familiar with tapping, study up or ask for someones help that is.
D
DayMack
Can't really go deeper as the mounting point is limited since it is on the air compressor itself, with half the threads completely missing
D
DayMack
Need to see a picture. I think you may simply have a broken off ****** that needs to be removed and replaced.
The mounting point ON the air compressor for the discharge pipe has half the threads missing. I can get a photo soon.
Walkers
Cave Creek Az
Usually the outlets on the tank are welded on female pipe threaded bungs that have pipe ******* screwed on.
joe49
Tonica, Il
You are not getting it. Get a tap the size you have and tap the hole till you have full threads again. Just do that and you will get how this works.
joe49
Tonica, Il
Keeping in mind his original post and sticking to that, would you care to name those various situations were you couldn't do it. Pipe threads are on a taper and can easily be tapped deeper to restore threads.
joe49
Tonica, Il
Answer to your thought is tap till bottomed then shorten the tap and tap more. As a example a tap for 1/2'' pipe is $10 that makes it a cheap consumable. Edit; agreed pictures will be helpful.
joe_padavano
Northern VA
It's impossible to provide a useful answer without a photo of the problem. We're all just speculating and unfortunately the OP's description isn't particularly helpful.
D
DayMack
Here are the pics.
  • I can go a little deaper but, we are trying to use the same screw and those top threads are where it grabs the most
If I tap without threads there, wouldn't that section need to be a bigger size? And if so, I would need a bigger screw, right?
I think I may just get a time sert kit
Let me know what you guys think, thanks!
D
DayMack
Air Conditioner compressor...And you guys were arguing pipe threads. LOL
If it were me I'd try a longer bolt just long enough not to bottom out, but first maybe try to chase the transition from the damaged to good threads with a tap. Or, would a Helicoil work? Never used them.
I didn't even notice that I didn't specify that. And I was getting confused lol. But I've seen that a time sert works better than a helicoil.
They want me to keep the same screw
Wrench97
Southeastern Pa
Try using a longer bolt with a nut threaded all the way up, thread the bolt in until it bottoms out then tighten up the nut to clamp the line in place.
larry_g
oregon
Shiet, now that you say that, I'm thinking a stud or some threaded rod.
That would be my solution also. Find a stud that will fit and thread it all the way in, Then use a nut on top of the fitting.
lg
no neat sig line
joe_padavano
Northern VA
Here are the pics.
And THIS is why you needed to post photos. Just get a helicoil. Done.
joe49
Tonica, Il
He did say, ''air compressor'' in the first post. Most of which have pipe thread.
JRC3
Southwestern OH
Still arguing. LOLOL I just sat back and watched figuring there wasn't near enough info to start providing and especially arguing an absolute solution. My original thought was that it was something like a little 1-3 gallon air compressor with an odd proprietary connection or something out of the norm. Then to see it was an A/C compressor. ahaha
:p123
Not making fun of you, DayMack, just razzing typical TGJF stuff. ha!
Jim greengo
Behind my house
Here are the pics.
Not the kind of compressor I was expecting. Hahaha
That's why pictures are so important.
Anyway maybe try a time-sert.
