Hey gang, I've been reading this forum as a lurker for a few weeks, and wish I had found it sooner in my garage build...lots of gold here.
I need some help with ideas for moving the heat around in my garage.
Here's the details...
28'x53' garage. 16' stem walls. 2x8 construction with R38 insulation. 14x14 and two 8x8 insulated doors.
Mezzanine down one of the long sides of the garage.
Reznor gas heater mounted to ceiling in SE corner.
Thermostat mounted to S wall at normal height.
The problem...
The garage is insulated insanely well. However, as is normal when the heater kicks on, as is normal the heat stays up high for the most part.
This was not a problem till we built the mezzanine.
Now that we go "upstairs" it is a big problem.
It is easily 20+ degrees hotter upstairs.
So downstairs you still need a jacket to work comfortably, while upstairs all you need is a swimsuit.
What I need...
I want to figure out a solution that will circulate/push down the heat to the main floor and make the whole garage more of an "even" temp.
Some of you, have undoubtedly dealt with a similar situation.
As of now the only possibly workable idea I have is to put 2 or 3 ceiling fans down the centerline of the ceiling with the blades set to push air down...but I don't even know if that would work.
Any and all ideas are welcome.
Thanks in advance.
The problem...
What I need...
Thanks in advance.
