mendoza0032
- Joined
- Jan 9, 2012
- Messages
- 10
Need some advice. Any help would be appreciated. So I removed some termite damaged drywall From my work in progress fixer upper home. And I found between the 2x4 and brick (not sure what you call it sheathing?) to be broken falling apart almost feels like a cement board. What would be the proper repair for this? So basically when from inside it went drywall/insulation-2x4/brick. I am concerned of elements seeping thru brick straight into walls. Is there supposed to be some kind of exterior sheet like a tyvek? House was built in 1978
