As a 99% newbie to DIY auto, I would really appreciate some advice here on adj. wrench (or spanner, as we call them in the UK)
Note I'm NOT referring to pipe wrenches here though.
My 1st question is - how important it is to have adj. spanners in one's tool box? I have a set of metric combination spanners up to 19mm, I also have a few large offset ring spanners - 22mm/24mm, 27mm/30mm, 32mm/36mm. Sockets wise I all metric sizes to 24mm, plus 27mm, 30mm, 33mm, 36mm.
I'm considering buying a couple of adjustables in case I run into 'odd sizes' nuts that my current set of spanners/sockets won't fit.
My 2nd question is - what size adjustables would you recommend for big size nuts/bolts - say above 30mm? I have a Bahco 12" adjustable for plumbing work - but thought it's not long enough to apply torque to big tight nuts... So I'm considering buying either a pair of 18", or a 18" plus a 24" - what do you think - is 24" an overkill for DIY use on cars/4x4s?
Your advice would be most appreciated - thank you in advance.
Namo Amituofo
Namo Amituofo
