help needed- running supply lines to propane tank
bigred292
Rhode Island
In the process of building my garage.... garage will have radiant heat in first floor- heat will be from Takagi Jr propane flash heater.
I'm planning on having 2 100 lb tanks for supply. Due to window clearances I have to put my tanks about 25 ft away from garage. I would like to keep supply line hidden- maybe run it in some conduit?
Any suggestions as to what I should use? Was going to run black pipe from unit to exterior wall, through ext wall, and drop down outside.
I'm pretty **** when it comes to how it looks- the area where it comes out will also be my patio.
Any help would be appreciated.
