littlejohn69
- Joined
- Oct 12, 2015
- Messages
- 3
Hello all,
I'm hoping that a kowledgeable someone can help me with my Craftsman Torque Wrench, 20 to 150 -lb range, Model 44595.
This forum appeared to be the right place to get the right help.
Wrench came apart on me.
At first I could hear a nut rattling-around inside the handle.
I popped-off the end-cap and indeed found a nut loose from the shaft.
As a "recovery" attempt I've adjusted the wrench to the scale top end, 150-ft-lbs scale.
My plan is:
With the adjustment at the top-end, reattach the nut (adding a dab of medium strength (blue) threadlocker). Plan to install the nut as close to the plastic partition as possible.
Maybe I can us an ice pick or something to spin the nut to that point.
Barring that, just get the nut onto the shaft (with threadlocker) threaded
-on enough to enable re-installation of the end cap.
Once the threadlocker has cured. I should then be "in about the right place" and then be able to use the wrench.
Am I on the right-track or way of base? Then this becomes a ratcheting breaker bar only.
Anybody have experience with this type tool and can offer any assistance?
Ideas solicited!
Thanks,
littlejiohn69
My plan is:
Ideas solicited!
Thanks,
littlejiohn69
