bandlaw
Greetings all!
I'm working on my shop electrical, and successfully installed a 100A subpanel and wired 5 circuits. Circuits 1 and 2 are for the workbench circuits, Circuit 3 is for the table saw, Circuit 4 is for the Air Compressor and Circuit 5 is for the Shop Vac.
Circuit 1 and 2 are the ones giving me problems. Here's the general idea:
There are three two-gang boxes and the left side of each outlet is circuit 2, the right side being circuit 1. The first two-gang box is a GFCI on each circuit, with the goal to provide load-side protection to the second and third boxes. The boxes share a common neutral and ground, which after study, appeared to be both more efficient and permitted by code.
Problem is, I can use all of the first box, and the "right side" of the second and third boxes (i.e. circuit 1), but one or both GFCI's will pop if I utilize circuit 2 at all. Below is the wiring diagram, and I'm hoping the folks that are knowledgable about wiring can help me troubleshoot what I did wrong. I followed the Black & Decker Electrical Wiring Guide, which had examples of GFCI protecting standard outlets downstream and a wiring guide for a common neutral. I'd like to fix it as is, if possible. If not, I suppose there are two other options: switch to GFCI breakers and put in standard outlets on the first circuit, OR add a separate neutral wire for circuit 1 and circuit 2.
Thoughts, help, desperately needed. I am stuck in the house for the snow-pocalypse in North Carolina, so I would love to get this last kink worked out. Thanks!
