Help on some needle bearings for an old Tiller
geomagno
Indy
Repainting an old tiller from a deceased family member - it may be a Merry Tiller or one similar. Has the old 3 HP Briggs motor.
When opening the gear box I found it missing several needle bearings. Can these be bought loose? I only see them set in a race.
G
geomagno
Indy
I agree on an entire new bearing. but I doubt this thing will be used much at all, perhaps a bronze bushing would be able to be sourced cheaper .Hard to say if it's worth it but sometimes we fix things because we want to, not because it's the most rational thing.
All true. This tiller belonged to my wife's granddad and it means a lot to her, which is why it's in pieces on my workbench getting sanded, primed, and painted. I would have been fine buying a newer used one but, again, I'm married.
G
geomagno
Indy
It's probably time for you to spurge on a "whole" bearing.
I'll try to figure out the measurements on a whole bearing. Can't imagine me getting it right on the first try.
alfadan
Augusta, ks
I can't see the seperation between bearing and arm. Is the race welded in? I can't see how they would have welded the race without fugging it up. They should be removable bearings and a nominal size if so.
G
geomagno
Indy
john.k
Brisbane Qld Australia
try 4140 HT rod cut to roller length as rollers.....I suspect there were originally cages .......I had some big cable rollers with busted cages (new bearings were $150 each) used cut wire to space rollrs out.
