Help painting raised lettering.
xbartx
So. Oregon
Any hints as to repainting the raised letters on this vise I'm repainting?
My hands are probably not steady enough to do it freehand. Would some kind of paint pad work best?
-Brad
Shiftless
East Bay SFO
Make up foam thing
dip in the paint
touch on the surface of the lettering
This is a fine technique.
But be careful with the amount of paint on the foam pad. You might want to have a scrap Of cardboard on your workbench to dab onto before dabbing on to your vise.
Another tool I sometimes use is a Q-tip. First I cut off the cotton swab end though. Just use the compressed paper shaft of the Q-tip as a dauber.
Here is a vise I repainted and highlighted the lettering using the above techniques.
aka Larry
Eastern, NC
Not sure if this is applicable to your vise, but I've used the 'dry brush' technique with good results.
Basically you use a small brush (like for models) and use just enough paint to get color on the brush. This keeps the paint from bleeding over the edges of the lettering. The only downside is this method requires multiple coats for coverage because of the fact the paint is so thin.
Here are the raised areas I painted on a couple of items (washer fluid cap, fuse box) in the engine bay of my Charger R/T.
Orangina
Germany, Berlin
I use a small, fine real hair brush –
and in case I've applied too much paint, cotton swabs q-tips to wipe it away along the edges.
For flat surfaces, I use self printable waterslide decals – or order decals from a cutting plotter.
Good luck,
Nick Rivers
USA
Skip the paint pens, brushes, and markers. There is a technique where a piece of fine cloth is wrapped around a rigid sphere. That is touched to the paint then touched to the surface of raised letters to only apply paint to the face of the letters.
It is a cloth ball applicator technique where the cloth is twisted and tied to form a smooth, slightly padded “face”. The ball is dabbed into paint, then dabbed onto raised letters.
Paint transfers only to the top surface, not the sides.
crguy
SW Washington
Those raised letters are often rough and uneven to start with. I've used a paint pen with acceptable results, probably as good or better than the original factory results.
Lassen Forge
I've always had issues with this no matter what I tried - someone told me the OEM solution is usually some itineration of a print shop inking roller - get a small amount of paint on the roller, roll it on some flat surface until It's relatively "dry" and THEN do the raised lettering.
I talked to a distant relative who actually knew this info firsthand that license plates used to be painted this way - they'd go through a roller that applied the paint to the top of the extruded letters/numbers in a much larger, industrial setting (GrayBar Lodging and Industries, inc.)
Beerhippie
Far NE Oregon
It's all going to depend on the quality of the castings of the vise.
This old Chas. Parker, for instance:
Nothing but a fine brush and steadied hand (not steady hand--that was a long time ago--but you can use the other hand or a rest to steady your hand) will do the trick. The irregularities of the casting are as high as the lettering in many places. I used a magnifying visor to enable me to see the original lettering.
