sweetk30
i have a friend with a waste oil heater in his shop . he has a 350gal tote for extra storage . but he has to pump the oil from the tote to the heater when needed .
he was thinking raise up the tote and let gravity do the work and flow from the bottom valve on the tote to the fill port on the heater tank . would be under 5ft tall .
so if oil is in the 7.5lb per gal range this is just around 2600 lbs of weight .
what size tubing should i use to make the stand ? thinking square tube .
i have some big welders and plasma to this wont be a problem . just the design is the major question . for safety and piece of mine .
thanks for any help guys .
350 gal oil spill in the shop to clean up
