help please
mwk57
wiring in metal built garage. that is my question, what why and where do i start with unfinished interior of my new shop that was left by bad contractor at a bad time frame for health problems for my family and i. just want to build one more hotrod before i check out. THANK YOU 1/4 mile
ducksface
A lot of guys will give you a LOT of information without even beginning to interpret your abilities.
Based on your question you need to consult a professional both due to your beginner status and due to your local compliance issues.
DO NOT act on any suggestions for diy given you.
Hot Rod Grampa
Near Cooperstown New York
Maybe a good place to start is draw out your vision of the space. Where you could see what machine and how much power that appliance will need. Include tools you will or plan on adding and research how much power they will draw. Don't forget lights, switches, fans, heaters. It's easy now. Difficult to add later. Then talk to a qualified electrician. Maybe you can do it all yourself. Maybe the sub panel box can be wired into the garage and you can take it from there. Like anything else there is a learning curve and only you can determine skill level, and comfort level. The electrician may even work with you by letting you do the dirty work of running the wires and mounting the boxes. Then they come in and do the final hook up.
